383 build help
Car: 1987 IROC-Z & 1991 RS
Engine: IROC-305tpi & RS-357(built)
Transmission: Both-700R4
Axle/Gears: IROC-3.23 & RS-4.10
383 build help
We own a 1987 IROC-Z. We are currently looking for a 383 stroker to replace the 305 TPI. We want to know what needs to be replaced, changed, etc for it to work. Will all the gauges work or will we have to replace some or all of them? Will we have to replace the radiator/ cooling fans? Would the fuel pump need to be changed? Any help would be greatly appreciated!
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 build help
Sbc is a sbc for the most part. Minor differences in blocks may dictate need for different starter, flex plate, oil pan, etc but theoretically all the other stuff will bolt up
If factory fuel injection and wish to keep it, you can. Just hook it all back up in the new motor. Now the heads on the motor would need to have correct accessory bolt pattern for the factory stuff to work. Factory rad can be used but i'd get it flushed and cleaned or buy a factory new replacement.
Ecm will likely need a chip burned for new motor however, depending how crazy you get with the combo
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 383 build help
There are a couple more things you'll need to replace if you keep the EFI. The stock 19lb injectors won't be able to support a 383, so you'll need bigger injectors that would be sized based on your anticipated horsepower levels. This selection will also largely dictate how the chip is burned.
The 305 & 350 cars also had some other differences, namely the knock sensor and the electronic spark control module. I'm not sure the ESC does a damned thing, so I don't think you'll benefit from replacing it, but you will need a new knock sensor. I assume that since it's the same block, that the 350 knock sensor will be fine with a 383. If it's not, it may need to be eliminated, which again, may require some special considerations in the ECM tune.
Re: 383 build help
We are not looking to keep the EFI, i apologize for not mentioning. The 383 stroker we wish to put in is carbureted and do not plan on fuel injecting it.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Andrew Prakash
Sep 8, 2015 11:48 AM
