91 firebird swap questions
Old Jul 11, 2013 | 02:00 AM
Aluseu's Avatar
I have a 91 firebird v6 auto trans and was wanting to do a 350lt1 swap with a 5 speed tran but my friend said the motor isnt an issue and its very hard to do a 5 speed swap, any of u guys know how or have done it? how dificult is it?
Old Jul 13, 2013 | 06:48 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 91 firebird swap questions
Use a V8 T5 behind the LT1. Externally, LT1s are almost identical to 1pc RMS SBCs
The issue comes from abuse. If you bang on it too hard, it will break. If this is simply to row gears on a cruiser, then a T5 will work fine
Old Jul 16, 2013 | 08:42 PM
Mikerace15's Avatar
Car: 1988 Red IROC-Z
Engine: 305 TPI V8
Transmission: Borg Warner T5
I did a T-5 swap on my 88 IROC. And it was a piece of cake. The hardest part was making sure I cut the hole in the trans tunnel in the right place and making it the correct size. And mind you I was 17 in high school at the time. (and yes I still have the car.)
xkingcodex
Feb 12, 2020 07:43 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
