V6 to small v8
Old Jul 20, 2013 | 11:06 PM
Choldren's Avatar
Car: Z28 camaro T-tops
Engine: 2.8 v6
V6 to small v8
I hav a 2.8 v6 5speed camaro and I was wondering if I could use the same transmission if its only a small v8
Old Jul 21, 2013 | 12:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can, but you'll need a V8 bell housing. And, the V6 input shaft is smaller, so you can't use a V8 clutch disk. I understand a 4.3 V6 S10 clutch disk will work with a 3rd gen V8 pressure plate.
And, you'll need to drive the car no harder than you did with the V6.
Old Jul 21, 2013 | 08:29 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: V6 to small v8
That's not true. The v6 trans isn't any weaker than the v8 trans.
Old Jul 21, 2013 | 01:36 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: V6 to small v8
The deeper the gearing gets, the less the torque capacity. So the V6 having a 4.03:1 first can't be as strong as the V8 2.95:1 first. case strength should be the same, shaft strength should be the same, but from the T10 to the T56 to the TKO, torque rating differs for each set of ratios offered.
Old Jul 24, 2013 | 01:15 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: V6 to small v8
I'm doing this right now. You'll need a V8 bellhousing, flywheel, pressure plate and a clutch disc that is 14 spline, 1", 10.5" diameter. I got the pressure plate from Rockauto (Sachs is the brand) and the clutch is from speedway motors, part number is 91015649. I'm hoping to drop it in this weekend.
NZKnight
Oct 15, 2015 02:47 PM
skinny z
Oct 5, 2015 06:23 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
