Looking into a L31 possibility
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Trying to look into swap possibilities...thought about the goodwrench 350 (too weak) and the ZZ4 (too expensive) so now I'm trying to gather intel for a L69 to L31 swap.
I want 300hp. 300+++ torque. Good drive ability and fun factor without the ZZ4 price. The goal is to stay below $3000. I am considering a new engine so the hassle factor can be reduced.
So I am looking into a L31 truck engine, but possibly modify the cam to LT4 specs and modify the heads with better springs etc... for more lift potential.
I will be using my stock q-jet.
I will be getting a new prom to try to match the engine capability.
I will be using Hooker 2055-1HKR's.
I will be using my Maganflow cat and cat back.
I want my engine to look as stock as possible, I don't want to have to buy a new hood to fit this engine. Will the intake make that an issue ?
Any comments, suggestions, ideas?
Chuck
Chuck
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Looking into a L31 possibility
L31 is a Vortec engine.
Do a search on here or Google about them , a million Vortec hot up articles about.
To use Vortec heads you need a special Vortec only intake manifold
Looks like a truck engine that is an LT4 cam and beehive springs away from being a very respectable and drive able street motor.
...anybody drop an L31 in an early thirdgen and have issues with the hood or anything else?
Heck, I might just get the engine as is from Jegs for $1900 and just call it good. Worry about the upgrading later. 250hp and 330 tq is already too much for the stock t5 anyway
Car: 82 Z28
Transmission: T400
Only the intake port shape and intake bolt pattern on the heads makes it any different.
HoosierinWA
Oct 7, 2015 10:15 AM
