World worst stuck screw
Car: 1986 Camaro Sport Coupe
Engine: 305 OHV
Transmission: 4-Speed auto
I had an engine on a stand and one of the bolts snapped and we can't get it out. We've tried everything up to and including oxy-acyteline. So my question is can you get away with 5 bellhousing bolts?
Re: World worst stuck screw
That's all the LSx motors have, for example.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
drill it out with a left-hand cobalt drill.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
you can get away with 3 BUT not recommended. I have had good results with heat and dry ice.i heat the offending member and chill the bolt with the ice ,it works.good luck
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
If its a half inch in, why not drill it out some and install a helicoil if you are worried? Or tap to a bigger size. At that point I wouldnt even try to get it out, just start drilling. Left handed bits are good because soemtimes the offending bolt will come out.
I just drilled and helicoiled a couple holes on my bell housing for my T56. And Ive also ran with a missing bolt and a couple shady threaded ones. Should be ok with just missing the one if you dont want to fix it.
J.
J.
LT1Formula
Oct 8, 2015 08:34 PM
Damon
Sep 26, 2015 04:29 PM
