Vortec 350, 292 cam and 305 heads
Old Sep 5, 2013 | 04:59 AM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
Talking to a friend who dabbles in engines and he recommended a Vortec 350 with a 292 cam and using a set of 305 HO heads. Said it wouldn't be to expensive and would be streetable. I've read the 305 heads on it would make the compression good enough for the cam. What are ya'lls thoughts and what kind of torque and HP could I expect?
Old Sep 5, 2013 | 05:24 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Vortec 350, 292 cam and 305 heads
Serious mis-match of RPM ranges. The 292 cam starts working about the same RPM as the 305 heads become a restriction. Try something more like a 268.
Old Sep 5, 2013 | 06:37 AM
"Vortec" = it came with better heads than any 305 ever did
"Vortec" w 305 heads = somebody took off the good stuff and put on crap
Leaving aside the matter of the cam, sounds like it's time to smile politely, thank him kindly for his willingness to help, and then ignore every word he said.
Old Sep 5, 2013 | 08:54 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
LOL, second that.
what is a 350 Vortec and 305HO heads? The 350 is a 350 vortec or SBC they both work with each other. So if you got a vortec block with all the vortec heads intake cam. You would throw out the vortec heads which will flow better (stock for stock) bolt on the 305HO heads and cam and then you have to but a non vortec intake to work with the heads.
So basically just got any 350SBC put in a cam and throw on 305HO heads and you will get more compression then the 083 heads is what I think he meant?
Old Sep 5, 2013 | 09:04 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
seems like a good way to wreck a good engine...
keep the vortec heads, upgrade the springs to match the bigger roller cam that you should install- the HOT cam kit from GM is a killer setup- and just try to wipe the smile off your face every time you get on it..
Old Sep 6, 2013 | 11:22 PM
hartsmike's Avatar
Axle/Gears: 273
Originally Posted by jjcuff1
LOL, second that.
Thats what he meant.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
