MSD pump and Corvette filter/regulator on TPI
Old Sep 10, 2013 | 11:47 AM
quick57's Avatar
Due to all the LS swaps out there Speedway and other dealers are offering the MSD external fuel pump and Corvette style filter / regulator. Is there any reason this setup could not be used in a TPI conversion?
http://www.speedwaymotors.com/LS1-Fu...Kit,41791.html
Old Sep 10, 2013 | 11:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: MSD pump and Corvette filter/regulator on TPI
The Corvette regulator/filter is going to regulate pressure at 4 Bar (approx 58 PSI). TPI runs on 3 Bar (approx 43 PSI). I'm sure it's possible to run TPI on 4 Bar (provided your injectors don't protest) with a modified PROM, but I don't really see the point. You'll have to modify the fuel rails to remove the existing FPR and to accomodate the returnless configuration of the Corvette regulator. It seems like a lot of trouble for no benefit.
Old Sep 11, 2013 | 06:24 AM
quick57's Avatar
The MSD pump has a maximum of 43 PSI and I was just going to leave the stock regulator in place. I am considering this option since I will only need to plumb 1 fuel line to the tank instead of 2.
Old Sep 11, 2013 | 06:58 AM
Jim85IROC's Avatar
I have yet to find a pump that can keep a steady unregulated pressure, which is essentially what you're asking it to do. Any voltage swing at all will cause the output volume & pressure to change, and the voltage in a running car is anything but constant.
The other issue is that the stock regulator changes the pressure based on the vacuum signal. Your design would eliminate what, which would require an entirely new fuel map in the PROM. Not impossible to overcome, but certainly a lot more work than installing the 2nd fuel line right next to the main one that you need to install anyway.
Old Sep 11, 2013 | 09:53 AM
quick57's Avatar
Thanks for your input. I will end up running the return line in order to satisfy the fuel map. Juice is not worth the squeeze here.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Sanjay
Aug 12, 2015 03:41 PM
