decisions decisions
Old Oct 1, 2013 | 09:48 AM
jacobd32's Avatar
Car: 1984 camaro z28
Engine: 305 for now
Transmission: t5 for now
decisions decisions
Alright here is the deal: I picked up an 84 z28 305 with a t5 the PO couldn't figure out what was wrong with it so I got a good deal. After investigation I found it was the head gasket. Tore it apart and fixed it still she overheats and smokes like crazy figuring probably a bad ring. O well just a 305 no biggy. Now comes the issue I have about 2gs and some body work to do so unfortunately ls1 t56 wont happen. I am thinking either a older 327 or a 5.3 vortec?? I want to keep a 5 speed for the fun factor after all it isn't a race car. So the question is will either of these bolt up to the t5 and what mods we looking at or should I just get another lamo 305? I've always liked the 327 but ya cant change the way engines are made. Thanks for the opinions guys.
Old Oct 2, 2013 | 01:50 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: decisions decisions
The 327 would bolt up as long as you have a two piece rear main seal. But if you'd be better off just doing a 350 of you're going to go through the trouble of swapping engines. The 5.3 is LS based so it isn't a direct swap and it's also not a direct fit for the T5 if I'm remembering correctly.
Old Oct 3, 2013 | 04:51 AM
jacobd32's Avatar
Engine: 305 for now
well 350 was my first choice, But I have had bad luck with a T5 behind a 350 that's why I was looking at the 327. A little smaller and a setup I haven't seen very often
Old Oct 8, 2013 | 12:46 AM
No4Play's Avatar
Car: 1992 RS Heritage Edition
Engine: LS6 Mut
Axle/Gears: Stock
you can pick up a 5.3 for cheap. find an ls1 intake and front accessories with a cam and you're looking at about 330rw through a t56. If you shop around for the parts you could easily do the swap for around 3g's. Then down the road you can bore it to a 5.7 and throw in a 383 stroker assembly. Now you have a forged iron block 383. plenty of power.
ZZ3Astro
Aug 13, 2019 12:57 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
3.8TransAM
Sep 3, 2015 06:38 PM
BlackTopKing
Aug 19, 2015 12:13 PM
