Whats agood donor car/truck for motor
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Whats agood donor car/truck for motor
The L31 350 was fitted in
1996–2002 Express/ Savana full-size vans
1996 G-Series vans over 8,500 lb GVW w/ 4L80E transmission
1996–1999 C/K full-size trucks
1996–1999 Suburban full-size long-wheelbase SUVs
1996–1999 Tahoe/ Yukon
1999–2000 Cadillac Escalade
2000 Tahoe Limited and 2000 Tahoe Z71 models)
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Gary and Vetteoz are completely correct, but depending on your overall goals, you may not necessarily need to restrict yourself to just that motor. Are you looking for a motor that you can just swap in, slap an intake & carb on and use? If so, then I agree with their suggestion 100%. However, if you're going to rebuild the motor you get, and especially if you're going to use different and/or aftermarket heads, your options for a starting point open up a lot wider, mainly to ANY 350 that is roller-cam ready.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Please be aware that not all 880 blocks are fully machined for a mechanical fuel pump, some have no coolant bypass hole at the pump and some don't make nice with several aftermarket timing covers.
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Whatever you buy make sure you get it machined and checked out before you go throwing parts at it
Car: 82 Z28
Transmission: T400
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
and what year sould i look in
