does removing egr effect your catalytic converter?
Old Oct 24, 2013 | 12:31 AM
asm383's Avatar
Car: 91 z28 convertible
Engine: 350lt1
i removed the air pump/egr all around and used the block off plates. i heard that the air pump heats up the converter do i need to remove the converters? also this is going into a 3rd gen so do i need different headers or can i use the lt1 aftermarket headers since i need the o2 sensor ?
Old Oct 24, 2013 | 12:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: does removing egr effect your catalytic converter?
Yes you need the 02 sensor.
You need headers and Y pipe 4 a 3rd gen, not a LT1.
Air pump pumps air into the converters helping burn off raw fuel. They will be fine without the air pump.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
dyeager535
Aug 28, 2015 08:10 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
