L31 FAST BURN HSR BUILD MISC QUESTIONS
Old Nov 28, 2013 | 09:22 PM
defresh's Avatar
Car: 91 CAMARO RS
Engine: 350ci
Putting together an L31 Fast burn HSR with an LT4 Hot cam. Will prob run 100 shot every now and then. Not sure of all the misc stuff. Head gasket (MLS bore size? or can I go felpro 1094), balancer size (6 or 8 in), ARP head bolts nec or felpro ok, pushrod length, high volume oil pump or not, injector size. Any other suggestion before I bolt this thing up would be greatly appreciated. I'm shooting for 420 horse and a reliable daily driver.
Old Nov 29, 2013 | 02:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: L31 FAST BURN HSR BUILD MISC QUESTIONS
Originally Posted by defresh
pushrod length ?
The required pushrod length you measure after you have everything together
Much debate but HP /HV pumps generally considered a waste on a street engine
Opinions will vary
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
3rdgenparts
Aug 5, 2015 11:57 PM
