1991 Pontiac Firebird V8 build
Old Dec 31, 2013 | 06:57 PM
Fighterofwoe's Avatar
Car: 1991 Pontiac Firebird 305''
Alright so I have a 1991 Pontiac Firebird that has a 305 V8 in it right now, but I want to put something bigger in it. My Brother is a mechanic and has a friend whose uncle builds racing engines for a living and can get me a 383 stroker for around $1600 dollars, crate engine ready to drop or I shop around for a 350 and swap my 305 for that instead. If I go 383, will I have to worry about my Tbi or anything like that? what all will I need to consider replacing along with the engine with each of these swaps?
While I'm under there I would also think about tranny work since mine is about to go out (I have an automatic transmission), so if anyone can give me advice on what I should do tranny wise (new/rebuild/etc) that'd be great. I'm trying to keep the cost reasonable (within a couple thousand dollars), I don't want to be super expensive or cheap but I'm willing to take the extra step if it's necessary. I more want the car as a cruiser or my hotrod for date nights than to take it and race it every weekend (I still want it fast) , the three pics below are of my car by the way.
Attached Thumbnails 1991 Pontiac Firebird V8 build-1388165993434.jpg   1991 Pontiac Firebird V8 build-548211_105834656257531_422866299_n.jpg   1991 Pontiac Firebird V8 build-61586_150681448439518_660406534_n.jpg
Last edited by Fighterofwoe; Jan 1, 2014 at 04:05 PM. Reason: Completely changed the info
Old Dec 31, 2013 | 07:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1991 Pontiac Firebird V8 build
https://www.thirdgen.org/forums/tech...formation.html
Originally Posted by Fighterofwoe
now that it isn't a daily driver I plan on doing everything I can to make it a monster.
I want some advice on what i should do ?
what route should I take ?
What engine should I put in it?
More info needed.
Your budget for starters.
Intended use ; cruiser , strip use ????
Fuel economy of any importance ???
What you CAN DO is only limited by your budget but higher Hp ( monster ) also requires spending $$$ on other parts of the drive line as well
so it will hang together so you need to take that potential cost into consideration.
Old Jan 1, 2014 | 03:52 PM
Alright I changed the question a great deal regarding my current issue to narrow it down a bit, hopefully that helps.
Old Jan 1, 2014 | 04:00 PM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
What about suspension? Those are pretty important for better ride quality
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
tyeo098
Nov 30, 2015 06:27 PM
Jlanz55
Sep 29, 2015 08:55 AM
ericjon262
Sep 11, 2015 06:07 PM
Street Lethal
Sep 7, 2015 01:09 PM
