What blocks are compatiable?
Old Jan 6, 2014 | 02:08 AM
Xephy's Avatar
Car: 1992 Camaro RS
Transmission: A4
I have a 92 Camaro RS 305 L03 and want to do a swap. Will any small block drop in without a problemas long as its a 1 piece rear main seal as well as 4 bolt main? I'm lookkng at some bare blocks and just need to know. Lastly, the other block would have to be for a my camaro year correct? Let me know please!
Old Jan 6, 2014 | 05:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What blocks are compatiable?
Originally Posted by Xephy
Will any small block drop in without a problem as long as its a 1 piece rear main seal as well as 4 bolt main?
Any factory or aftermarket SBC is a drop in inc this one if your budget runs that far
http://www.theengineshop.com/product...4---600hp.html
The engine doesn't have to be 4 bolt and if it is a earlier 2 pce RMS seal engine ,you only need a flexplate to suit that engine, nothing else changes
Old Jan 6, 2014 | 06:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume the reason for the question is "Location: San Diego".
Technically, any engine you install must be '92 model year or later. But, an older engine rebuilt to '92 specs should be acceptable.
The key is not making the smog inspector suspicious. If everything visible looks right, and it sniffs clean, then there really isn't any reason for them to look to see if you have an older block.
For the record, no 3rd gen came from the factory with 4 bolt mains. But, that isn't an issue to a smog inspector. If you have a 4 bolt main engine, exactly how is he going to know that?
Old Jan 6, 2014 | 09:03 PM
Xephy's Avatar
Car: 1992 Camaro RS
Transmission: A4
I assumed it was a 4 bolt main. I didn't want to have to get a flex plate and do all the conversions or whatever it may be. I have to register and smog the car next week. Then my registration will be up in 2 years. Within the 2 years, i'll be able to do whatever I want to the car.
Old Jan 7, 2014 | 12:23 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
There are no conversions with a SBC swap.
All you need is a $30 flexplate if you install a 2pce RMS engine
http://www.summitracing.com/int/part...make/chevrolet
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
