K Member Removal
Old Feb 4, 2014 | 09:16 AM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
K Member Removal
I've been doing a lot of searching on the forum for a detailed outline on how to remove the old k member when doing the lsx swap. Does anyone have a link to an old post, or a sticky?? Wanting to get started on the next steps!!
Thanks!!
Old Feb 7, 2014 | 07:39 PM
Pocket's Avatar
Car: 91 Trans Am
Re: K Member Removal
6 bolts hold it to the frame
I prefer to leave all the suspension attached, so I d/c the front brake lines, pitman and idler arms, and upper strut nuts. Whole assembly should fall out the bottom. When there's a drivetrain still installed, I put Dolly's under the oil pan and trans, then lift the car off it
Be sure to chain the springs to the a-arms or you risk a trip to the doc/dentist
Old Mar 6, 2014 | 05:46 PM
Ikes 91Z's Avatar
Perfecto. Took it off the other night. Other than a lot of rust since it's over 20 yrs old it came off pretty easily. Ordered the new bmr and this ls conversion is well underway!
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
3rdgenparts
Aug 8, 2015 07:09 PM
