bbc 494
Old Feb 12, 2014 | 11:35 AM
tommy64red's Avatar
Car: 1986 I roc
Engine: 494 bbc
Transmission: turbo 350
bbc 494
hey how good would this bbc run in my 1986 camaro
I have 454 030 over 4.25 stroke 6.35 rods probe pistions com soild cam 590 .598 lift 0.50 242 252 extrem comp cam 781 oval ports heades 2.19 1.88 vavles and they have been worked pp dual plane intake crosswind proystsem 986 carb with hooker 2226 headers how much hp do you guys think would have and what would it run like in a 1/4 mile IT HAS about 10-1 final compression . thanks. tommy
Old Feb 12, 2014 | 08:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: bbc 494
It would run just as good as any other BBC build. It all depends on the quality of the build and how well the parts are matched. Based on the parts you have listed, probably in the mid to high 10's.
Old Feb 13, 2014 | 11:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: bbc 494
Originally Posted by tommy64red
... com soild cam 590 .598 lift 0.50 242 252 extrem comp cam ... dual plane intake crosswind proystsem ...
Sounds like you're building a race engine. So, why that choice of intake? A single plane (and I'd take an Edelbrock or Holley over Professional Products any day) would probably do you better.
... what would it run like in a 1/4 mile ...
Transmission?
Rear end?
Tires?
If all of those are "stock", I'd say 14's.
Got a 6-point in the plans?
Old Feb 13, 2014 | 12:11 PM
tommy64red's Avatar
Car: 1986 I roc
Engine: 494 bbc
Re: bbc 494
Transmission?
Rear end?
Tires?
I have a built turbo 350 trans and tou torque convert built for around 3500 to 3800 stall rearend is 9" ford need help for gear ratios not for sure what to gear it and tires not sure what I need thank for the reply .
Old Feb 14, 2014 | 10:37 PM
1gary's Avatar
Re: bbc 494
http://www.wallaceracing.com/Calculators.htm
Loudnproud86
Jul 14, 2016 12:59 AM
redformula88
Oct 14, 2015 06:08 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
