95 Z28 LS1 swap to SBC Gen1, Ign & general swap info
Hello all and thank-you in advance! Wandering about my wiring system and using standard HEI Distributor (flat/crab style)..do any of u see issues here, and could let me know some specific wiring info for HEI Dist. as well as any computer problems I don't know about..Please understand I am Very Mechanical and all around fix it type of guy on a roman noodle budget !
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 95 Z28 LS1 swap to SBC Gen1, Ign & general swap info
LSI doesn't have a dist or provision for it
GMPP have a conversion kit available to run a dizzy
http://ls1tech.com/forums/generation...-work-ls1.html
http://www.chevyhiperformance.com/te...ower_increase/
Transmission: 4L80E/4L80E
First, welcome aboard thirdgen.org.
Second, are we talking about a '95 Z28 chassis? If so, that is "4th gen" f-body, not 3rd gen. This site is dedicated to 3rd gen f-bodies.
Also, a '95 would have an LT1, not an LS1. So something doesn't jive here.
If you're wanting to put a Gen I SBC into a '95 chassis, #1, that is a discussion for another board. #2, for the record, the Gen I SBC HEI won't fit under the cowl of a 4th gen f-body.
