86 firebird BOP build begins with.... questions
Old Feb 21, 2014 | 06:45 PM
Pontiac_Chief's Avatar
I have had this whip for some time now and was going to do a turbo lsx build, but then I just got offered a sweet trade for this 455 that has forged internals stage two heads and Rochester carb all fresh rebuilds. Id like to drop this in the bird but I also want to do a hawks thirdgen sophn front end. This comes with engine mounts for sbc or bbc or non ..... what do I do here? I know the stock k member can be used with A body engine mounts from a remotest or gto, but again I want to all sophn. Wil those mounts still bolt up to the spohn k member?
Old Feb 26, 2014 | 01:31 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: 86 firebird BOP build begins with.... questions
I thought the GTO mounts had to be welded on to the factory k-member?
Old Feb 27, 2014 | 09:52 AM
i was also told cutlass mounts, im not sure on the modificastions needed but i was told these mounts require the least and there are no mounts that require NO MODs
Old Feb 27, 2014 | 09:54 AM
Im most likely not going to make the trade and hold on to my 50 chevy project for later.
i think im going to stick with the original plan of turbo lsx at a strong 450whp
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
sreZ28
Aug 14, 2015 07:48 PM
