383 Stroker in my 91 RS
Old May 1, 2014 | 07:45 PM
Michael Hahn's Avatar
I am currently installing a 383 Stroker in to my 91 RS and i want to eliminate all the smog and emissions as well as Ac/Heat... I was wondering where this all plugs into behind the fire wall so i can remove all the wires to make it look a little bit cleaner.... Can anyone help me?
Old May 1, 2014 | 08:29 PM
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
Re: 383 Stroker in my 91 RS
some of it comes from behind the brake booster and some comes from the passengers side kick panel and up the fender just beside the ac box
Old May 1, 2014 | 08:32 PM
I would hook up what you will be using then eliminate what you don't need
Old May 1, 2014 | 09:14 PM
Already have everything marked on what i need and what i dont need... Just checking to see where everything is so i can make it simple tomorrow when i start unplugging wires.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
