84 camaro LT1 Swap help
Old Jun 15, 2014 | 01:13 AM
21941181's Avatar
Car: 84 Camaro
Engine: In the process of an LT1 swap
Transmission: 4l60E
Axle/Gears: haven't broke em yet
84 Camaro had a 305 carb with 700r4..swapping a 94 LT1 out of a buick roadmaster with the 4L60e trans...need alot of help but I'll start off with where I'm currently..Ive read alot about people saying they used the stock 305 mounts(clamshells)..I ordered the moroso solid mounts for my car and I cant get everything to line up..my problem is for whatever reason my engine and tranny are sitting crooked..tailstock is hitting passanger side of tunnel..did i put mounts in incorrectly..I have ac bypass pulley on eng already..i put mounts on car in the stock 305 location and I put the mounts on the eng in the stock buick location..need some advice here so I can get out and have some fun before it snows again here in wisconsin
Old Jun 16, 2014 | 08:12 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 84 camaro LT1 Swap help
The engine side clamshells must be from a SBC. One of the LT1 clamshells is completely different (pass I think)
Old Jun 16, 2014 | 08:28 PM
21941181's Avatar
Car: 84 Camaro
Transmission: 4l60E
Ok so you have to use stock mounts and there is no way to use the solid mounts
Old Jun 16, 2014 | 10:36 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
No. You can use solid mounts. Likely you have one side mounted too far back. there are two sets of mounting holes on the k member.
Old Jun 18, 2014 | 05:34 PM
21941181's Avatar
Car: 84 Camaro
Transmission: 4l60E
okay thank you for your help so far I'm going to pull the motor and trans back out and look at the mounts hopefully thats all it is
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
