84 H.O. with a 85 tpi swap?
Car: 1984 camaro Z28 H.O
Engine: 5.0 H.O
Hello everyone, I have a 84 H.O 305 5speed and I was wondering if I swap my 85 305tpi engine with it what all would I need? I have the engine sitting in my wrecked iroc and it's all beside some front end wires that got ruined in the accident. The iroc has the 700r in it, but if I switch into my standard transmission will the old flywheel work? Or will I need to purchase another? Any help, please and thank you
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 84 H.O. with a 85 tpi swap?
since you have a complete donor car. it will be easy enough. you can use your flywheel and trans . you will need to swap the wiring harness complete with the ECM and you should be good to go
Engine: 5.0 H.O
I'llrocya
Feb 2, 2016 11:43 PM
Sanjay
Aug 12, 2015 03:41 PM
