350 head and cam slection?
I am finally swapping out my lame 305 for a '92 350 tbi four bolt main. I will be converting it to a carved motor with a 600 cfm edelbrock and a edelbrock performer intake and I'm in the process of updating the exhaust. Since my 350 currently doesn't have a set of heads I am wondering what heads I should use (preferably junkyard heads since I'm on a budget) and which cam I should go with? Since its my daily driver I'm more concerned with torque in the lower rpm's than I am with spinning it in the higher rpm's, mainly a good street car that makes an occasional trip to the track. Any help would be greatly appreciated.
Car: 1984 camaro
Engine: 1970 l48 with vortec heads
Transmission: 700-r4 from a diesel
Re: 350 head and cam slection?
Also you may want to look at the performer RPM intake, it's a little taller and more expensive but it's worth it.
Car: 1984 camaro
Well using comp cams digital dino and speaking with them to select the right settings, it should be making 420-430 hp and around 445 ft/lbs I dont have the numbers in front of me atm but I can find them. You can go to camquest.com and play around with their dyno.
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Vortec and 268h will make a good combo. Watch the lift on vortec heads. Pushrod slots wont handle over .480
Transmission: 4L80E/4L80E
You do need to be aware of retainer to guide clearance. Usually best to cut the spring seats and tops of the guides for better valve springs and positive seals.
Car: 1989 IrocZ
Thats not what I said. Slots , or holes where the pushrods goes through the head has to be enlarged for 1.6 rockers. Its not worth going over the max lift , as these heads dont flow in the .500 that well anyway. I did a 357 for a monte carlo with just a 268h which is only 218 dur and .454 lift , 1.5 roller rockers and these heads and duel plane performer and 600 edelbrock. Its a dynomite combo for the street with a 2400 stall. All we did was swap to the 268h spec springs. If your going to go .525 lift, get a set of AFRs as you get the added benefit of running higher comp. Thats just my opinion, I wouldnt dump money into cast iron vortecs. Note to op, big is not your friend on the street unless you do big cubes. Performer manifold , exactly what you want. Its 5500. Small(er) (than most will recommend here)cam and modest stall. It will make all the power off idle, and pull strong to 5-5500.
Car: 1989 IrocZ
You call it what you want. Its a pushrod slot it isnt round. Gonna argue with comp cams?
http://m.summitracing.com/parts/cca-4710
You dont have to school me on late model chevy engines, lol. And yes some production vortec heads need to be elongated towards the stud with 1.6 rockers. Btw,What else can you add to helping this member with his questions besides trying to be an english major? Get your facts straight before you start correcting people.
Car: BUILDING 1985 HARD TOP T/A
Engine: sbc
Transmission: stick
Axle/Gears: GM
Screw in studs are great, for added stability, strength and better resistance to being pulled.....
If your going to run a high lift & duration cam, large valve heads and spin it over 7grand!
It is a very solid suggestion, but for what YOU are saying that you want. ... just have the vortec heads cleaned up (fresh valve job, seals,locks & spring's, that are matched to the cam) , and have the machine shop" pin" the factory rocker studs.
It's cheaper & will definitely hold up to what YOU say that you want it to run.
Car: 1989 IrocZ
Def pin them. That is a good recommendation for what your looking for.
If you do use 1.6:1 rockers on Vortec heads, it would be a good idea to get a 1/2" drill bit and open them up - no $40 tool required. The tool is a good idea for '87-earlier heads that used non-self-aligning rocker arms, which require a more precision opening, but '88-later (including Vortecs), or when using guide plates (in which case the slots should be opened up to round holes), not required.
Now that, I would agree with.
Of course, given this:
" I don't want to go to big on the lift anyways cause I want to maintain drivabilty."
...There's really no reason to use 1.6:1 rockers.
Engine: sbc
Transmission: stick
Axle/Gears: GM
I would have to agree with 5-7, unless you don't have a set of self aligning roller rockers, (even then, I think that buying a set of 1.52's would work out better for your application ). But definitely get a set of RR'S, if you don't already have them.
Car: 1989 IrocZ
So when are you going to respond the this poster or you going to go back and forth with me and not interject anything worthwhile? Your wrong plain and simple and if you want to take your ball home because you think your in the right, do so. They are slots before 87 and after. And whether they as you think are holes or not dont cost anything. I never said to machine anything, as a matter of fact if your actually reading anything Im writing, im telling him the cheapest possible route from point a-b. As a moderator Id expect more than this back and forth bs with the correcting of post grammer. Waste of money is machining these heads for a bigger cam than needed. These heads dont flow well over .500. Poster is on a budget and asking the best way to do this with cam recommendations. I responded, and your response is to nitpick a post. Whatever. Have you used these heads on anything?
Good cam recomendation would be something in the neighborhood of 430 -440 intake and 450 exhaust. 204-208 in duration 210-214 ex. Good street drivability combo with 1.5 rockers. Those heads will shine in that area and are built for tq. I know a 268h is a flat tappet but plug that into a comp cam cam program and see if you like it. Cheap performer intake and 600 carb will be fine. Power will be off idle to around 52-5500 rpm. Good for cast pistons. Cheap on a budget and if your local to me I have my old set off my 96 tahoe you can come and take if you'd like. Just need to cleaned up and checked.Dont mind at all to help someone out.
Engine: sbc
Transmission: stick
Axle/Gears: GM
Sorry about the mix up, thought you were the original poster of this thread, LOL! Sometimes my service and phone hang, that pm was meant for. beastin91rs
Engine: sbc
Transmission: stick
Axle/Gears: GM
Anyways, you can do as suggested here or for a few dollars more, buy a brand new set (eBay, summit racing sells there too, $520.00 ($260 a piece )for a new set, versus $450 for old rebuilt set. & that is if you get lucky and the junk yard set check out and you don't have to buy another) .
Car: 1989 IrocZ
Anyways, you can do as suggested here or for a few dollars more, buy a brand new set (eBay, summit racing sells there too, $520.00 for a new set, versus $450 for old rebuilt set. & that is if you get lucky and the junk yard set check out and you don't have to buy another) .
beastin91rs, stick with 1.5:1 rockers and you won't have to worry about the pushrod holes. Just make sure your heads can handle whatever lift at the valve you choose. Factory Vortec springs aren't good for much more than a factory Vortec cam, so replacing the springs is always a good idea with these heads. But, the guides are pretty big inside the spring, so either have the guides cut down (which will also allow more valve lift, if the top of the guide is also cut down), or use beehive springs.
These articles are a little old, but still have good info about prepping Vortec heads for more lift:
http://www.superchevy.com/how-to/148...ds-valve-lift/
http://www.carcraft.com/techarticles...pring_upgrade/
Oh, one last thing to consider: I know you talked about junk yard and budget, but you may want to take a look at this kit:
https://sdparts.com/details/scoggin-...ter/sd8060akit
Or for a little more lift capability:
https://sdparts.com/details/scoggin-...er/sd8060rakit
If you get Vortec heads from the junkyard, you are going to have to have a shop go through them, buy new springs, buy the intake, buy gaskets, etc., etc., etc. This kit has everything you need to bolt them onto the block. By the time you get everything you want/need with the junk yard heads, you very well may have spent more than what this kit (with all new parts) would cost.
Something to consider...
Engine: sbc
Transmission: stick
Axle/Gears: GM
Well, If he doesn't want them, pm me with spec's & price (also building a 383 for another project )
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: 1989 IrocZ
I dont know why you keep refering to me recommending a 1.6 rocker. Where are you getting this? I posted that link to show comp cams calls it a slot, I didnt recommend the tool. Im not getting where your going with this. Can you enlighten me? Last thing I would be doing is referencing magazine articles for info. Main thing Im tryin not to recommend is for the poster to "snowball" the build. A little more lift ? Build it for what you want now for a baseline and need be, upgrade at a later time when you want more power. Its never enough, we all know that. Pick a plan , stick with it.And behive springs?You break a beehive, you drop a valve. Behive lighter, totally unnessasary in this application. Plus expensive. 5500 redline. Hp z28 springs fine. They actually used to come on the sdce vortec head package. Don t know if they still offer them. When they did it was about 600 a set. But thats going back a few. Take care.
Car: 1989 IrocZ
REREAD PLEASE? I said I know its a flat tappet but just for comparision. Just for reference in finding a roller cam with specs close to that. Never said to downgrade. I did not write this. Take care.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
