2jz swap
2jz swap
I have a 87 camaro no engine or Trans I want to put a 2jz in it I found a used one has under 50k miles on it it is a complete engine and has twin turbo set up and intercooler as well. I know they sell a conversion kit for a c10 Trans would this be possible?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 2jz swap
Time, money and fabrication skills can swap any engine/driveline you want.
If you have enough fabrication skills then such a question doesn't need to be asked. Do the swap. Document and take lots of pictures to show everyone what you did.
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: 2jz swap
I was gonna do this swap to mine as I also love 2JZ's and some buddies have done some amazing things with stock JZ's. After adding up the costs of a GTE ($2000) then a rear sump pan since most were front sump, then computer etc it would have cost more then I wanted to spend
Jay
Jay
Re: 2jz swap
Jay
Jay
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Hello, Michael
Aug 20, 2015 03:19 PM
