305 from an 86 caprice into a 2000 v6 camaro
Old Oct 8, 2014 | 01:14 PM
HamburgersSean's Avatar
Ive got a 1986 caprice with a 305 sbc collecting dust and I was thinking of buying a car to swap the motor in to as its still in good shape, just dont like the car anymore. Just wondering if anyone could tell me if it would be a bolt in swap or what id have to do to get it to fit in and hook up. Its an automatic v6 car. Also the 305 being carbuerated, would it fit with the hood or would I need to get a scooped hood for the card/air cleaner? Thanks I advance. -Sean
Old Oct 8, 2014 | 06:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 305 from an 86 caprice into a 2000 v6 camaro
2000 Camaro isn't a third gen
Old Oct 11, 2014 | 01:53 PM
Pocket's Avatar
Car: 91 Trans Am
The 3.8L is better in every way from an old carb 305
Old Oct 13, 2014 | 06:54 PM
couchmotors's Avatar
Car: 1991 camaro rs
Engine: 496 big block
Transmission: th400
Axle/Gears: stock rearend. 3.23
The 3.8 has more HP than that 305 ever will. Its rated at 200 if your set on swapping engines find a ls1 and go that route. The trans bellhousing will need to be changed. The 4l60e has a removable bellhouseing and the v-6 has a different bolt pattern
Old Oct 14, 2014 | 05:15 AM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
The 4L60E was a piece unit until 97.He'll need a 97 or later to have a removable bellhousing.
Lbibb
May 5, 2016 12:00 AM
Fireslash
Apr 11, 2016 06:43 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
