Problems with ground after engine swap & adding headers
Old Oct 28, 2014 | 09:30 AM
deriek's Avatar
Car: 91 camaro RS/B4C
Engine: 5.7 TPI
Transmission: 4 spd Auto
Axle/Gears: 3:23
Has anyone experienced Issues with their car after an engine swap & replacing stock manifolds with headers?
Having some issues, high BLM, poor idle &misfire as well as low power.
Any experiences with these kinds of issies coming from poor ground?
Old Oct 31, 2014 | 05:38 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Problems with ground after engine swap & adding headers
A poor ground can cause a multitude of wierd issues. Double check your battery cable to block connection and cable to chassis. Next, check the cyl head to chassis connection. If those are good move on to the harness to head(s) connections. Front the factory, 3rd gens use studs to hold the ground rings on. These work loose at the cyl head and can cause a weak ground, esp as oil impregnates the threads
Issues with the O2 sensor are common after installing headers. Check out a heated sensor
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
