Fuel pump Question
Old Nov 5, 2014 | 08:42 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Fuel pump Question
So in going from TBI to carb, how would the electric in tank pump work? I understand that a regulator is needed to drop the fuel psi, but how would the pump still work properly? I heard it doesnt require the ecm, but what runs it? What causes it to prime? Rather lost on this matter, help!
Old Nov 5, 2014 | 09:45 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Fuel pump Question
12 volt switched and the fuel pump oil pressure safety switch on engine.
I'll try to word this simple so it's easy to understand.
You turn ign. on and for X seconds the pump will run with 0 oil pressure, with in X seconds if there is no oil pressure the pump stops receiving voltage and turns off.
You turn on ign. then start engine, the pressure switch sees you have oil pressure saying engine is running and everything is ok, so pump keeps getting voltage and keeps running.
The pump and the oil pressure switch is wired through a relay
Old Nov 7, 2014 | 08:12 PM
Car: 1991 Camaro RS
Engine: 5.0 L03
So does the fuel pump work regardless of the ecm? Sounds like its an independant system working off of the ignition only. Is that accurate?
Old Nov 8, 2014 | 05:06 PM
Car: 1988 Camaro
Yes correct, the fuel pump works regardless of the ECM.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
