removing wiring?
Old Nov 8, 2014 | 04:05 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
removing wiring?
My car was originally a 305 tbi but I'm in the process I'm swapping in a 350 with a carb. This may be obvious but I wanted to make sure but can I remove all of the wiring harness in the engine bay? Is there anything I'll have to keep?
Old Nov 8, 2014 | 04:07 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: removing wiring?
You can remove most of it, just keep the stuff you want to still work
Old Nov 8, 2014 | 05:09 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Ok I'll have to pick up a manual that shows the wiring. I'm not using ac so will the wiring for the power windows and wiring for alternator and starter be it pretty much?
Old Nov 8, 2014 | 07:06 PM
midias's Avatar
Depends if you want the gauges to work.
Old Nov 9, 2014 | 12:28 AM
Night rider327's Avatar
Car: 1988 Camaro
The underhood wiring you need to keep is for the starter, alt., battery, elec. cooling fan (if you have an elec fan), oil pressure sender, water temp sender, tach, windsheild wipers, front lights (headlight, turn signals, etc), heater box wiring.
There is 2 main harness under the hood that breaks up into other mini harness.
The wires you need to keep is from the driver's side firewall harness. About half of those you need to keep.
You don't need many, if any of the harness that comes from the pass. side up between fender and firewall.
All of your power windows, power door locks, power mirrors, etc wiring is inside the car, not under the hood
armybyrd
Dec 5, 2015 09:22 AM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
