things i need to know about swapping out a 305 for a 350
Old Nov 14, 2014 | 08:33 PM
killswitch_313's Avatar
Car: 1987 camaro
Engine: 305 V8 LG4
Transmission: 4-speed automatic
I have an 87 Camaro SC with a carbureted 305 that I'm wanting to swap out for a 350. How difficult is this to do? I'm still learning when it comes to this stuff so bare with me lol. Is there a lot of changes to be made as far as mounts and all that goes? What all needs to be changed in the car after the swap. Any information would be greatly appreciated guys
Old Nov 14, 2014 | 09:14 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: things i need to know about swapping out a 305 for a 350
the 305 and 350 (as well as the 327, 283, etc) uses the same mounts, trans pattern, etc.
For a carb'ed to carb'ed engine swap it's a simple remove and replace.
The only probs you may run into is acc. drive system/pulleys, etc and even then it's no big deal. The ones on the 305 will fit the 350
Old Nov 14, 2014 | 09:59 PM
Car: 1987 camaro
Engine: 305 V8 LG4
So would there be any issues when swapping a carbureted engine for a TPI engine?
Old Nov 16, 2014 | 01:34 AM
Car: 1988 Camaro
Yes you get into a lot more issues when going from carb to TPI
You will need the in tank elec fuel pump, pressure reg, fuel system, computer, engine wiring, etc from a TPI car and swap all that over to the carb'ed car.
Reborn756
Sep 4, 2015 03:42 AM
NinjaNife
Aug 23, 2015 11:49 AM
Bob88GTA
Aug 18, 2015 03:31 PM
st.evel07
Aug 13, 2015 06:15 PM
milk
Aug 10, 2015 06:26 PM
