which intake to use
Old Dec 22, 2014 | 11:45 PM
pearlspud's Avatar
which intake to use
I have an 83 z-28 and I'm swapping a crate 350 that I picked up from a friend but I don't know weather to use the original intake from 305 originally on the car or a duel plane intake I found in the garagethrew the pictures which one would work best?
Attached Thumbnails which intake to use-20141219_145402.jpg   which intake to use-20141219_145424.jpg
Old Dec 23, 2014 | 01:59 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: which intake to use
What are your end goals? The first manifold will allow use of different carbs while the second one looks to only accept a spreadbore type carb such as a Rochester. No sense in using the spreadbore manifold if you plan on a different carb later. jmtc
Old Dec 23, 2014 | 04:04 PM
Night rider327's Avatar
Car: 1988 Camaro
The 1st one (looks to be edelbrock performer), but man it looks to have seen much better days.
See if you can get the water neck bolts out with out them breaking 1st, then check all other holes, then try to clean it up .
Old Dec 23, 2014 | 06:23 PM
pearlspud's Avatar
I cleaned up the first one got the water neck bolts out and everything else on it. It actually looks pretty good do i need to put any of the sensors and the egr valve back on the intake because the "elderbrock performer" dosent have a spot for it?
Old Dec 23, 2014 | 06:47 PM
Car: 1988 Camaro
Look in your 1st pic... Center, straight down at the bottom. See that plate with 2 Allen head bolts. That's an EGR block off plate.. Remove it and your EGR valve will bolt right up.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
