Oil pan options
Old Jan 8, 2015 | 03:00 PM
mcweens's Avatar
Car: 1987 IROC-Z & 1991 RS
Engine: IROC-305tpi & RS-357(built)
Transmission: Both-700R4
Axle/Gears: IROC-3.23 & RS-4.10
Oil pan options
I'm putting in a 406 small block in a 1987 IROC this summer, and i was wondering what oil pans choices are available. I know the front crossmember between the lower control arms limits the size oil pan to stock volume. On the other hand, i can't seem to find a stock volume oil pan that will work with a 3.75" stroke. Any suggestions? Any and all help is always appreciated.
Old Jan 8, 2015 | 03:13 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: Oil pan options
The Kmember does not really limit you that much.
I run a summit 7 qt. kicked out sump pan in my 1988 camaro. My dad has the same pan on his 1982 firebird.
Both has stock K members.
I posted pictures on another thread, take a look at my post on this thread https://www.thirdgen.org/forums/tech...se-hooker.html
Old Jan 8, 2015 | 10:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Oil pan options
Back when I had a SBC in my car, I ran a 7qt Moroso pan with a stock k-member with no clearance issues.
Pan volume is in the sump. There should be very little oil at the front of the pan so a deeper pan at the front is not required. It only needs to be deep enough to clear the crank and rods.
Old Jan 9, 2015 | 01:32 PM
mcweens's Avatar
Re: Oil pan options
That's great to know, thanks guys. Any part numbers on those oil pans? I'd like to look at the prices
Old Jan 9, 2015 | 01:45 PM
Car: 1988 Camaro
Re: Oil pan options
The pan I used $79.95 http://www.summitracing.com/parts/sum-g3502 and of course you have to buy/install the longer oil pump pickup on your oil pump
Which I used the summit brand $17.97 http://www.summitracing.com/parts/sum-g3502p
So $98 total
Old Jan 9, 2015 | 02:06 PM
Mr.Gordon's Avatar
From: East coast, northern. Gonna head to Fla. soon, retirement .
Car: Got me a nice little '86 Z28.
Engine: A brand new 350 with a forged lower
Transmission: 5 speed, TKO600.
Axle/Gears: 10 bolt 373 modified zexel.
Re: Oil pan options
FWIW, on ebay there are deep pans available for either 2 piece or one piece rear mains with the pickup included. I have one on my '86 and the problem I had was the starter was rubbing on the bigger pan. Got a small gear reduction starter from the same seller for cheep and they both work great! No leak's and the starter whirr's my engine over like it's a low compresion engine, and I'm at 12.5-1.
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
