Out with the TPI and in with the Carb.
Old Feb 15, 2015 | 12:41 PM
3genRS505's Avatar
Okay I have a 90 RS camaro. I wanna change it to A carb setup I have a 1985 305 ci I wanna put in the 90 camaro RS.. Do I take the computer and strip the wiring harness?? Out of the 90 and Make one for the 85 motor to work?.. How would I do this..any ideas.. Jus's stuck on this wiring deal I know there a passlock on this camaro too..so would it be better just to rip it all out an juss run a wiring harness for a carb setup?
Old Feb 17, 2015 | 09:58 PM
hdavis2005's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI to 305 carb
Axle/Gears: 323
Re: Out with the TPI and in with the Carb.
You will find all the info you need on this site. Just Read!!
I did mine with no real problems. Just take your time and you guessed it...Read!
Old Feb 18, 2015 | 07:20 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
You 90 RS should have a TBI, not TPI... at least from the factory.
Replacing the 90 305 (roller cam) with an 85 305 (flat tappet cam) is a step backwards. Also, you will be switching from a 1 piece RMS to 2 piece RMS block, which means a different flywheel/flexplate.
"Passlock" = VATS or Vehicle Anti-Theft System. There are threads about bypassing it. But, if you are removing the ECM, you will also have to change how the fuel pump relay is wired. I think the '85 carb cars had a mechanical pump, not electric. So, the 85 ECM won't help you with the fuel pump relay.
Finally, why do you want to switch from a computer controlled fuel injected system, to a computer controlled carburetor?
Old Feb 18, 2015 | 12:49 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
It's rather easy. On my 89 bird it had to many bad sensors to even run so I went to carb. the computer and harness are on passenger side from fender. That can all go. All of your main wires for distributor ect. Are on drivers side.
As far as motors go. I just swapped from my tbi intake to a carb intake and swapped distributors. It's pretty straight forward.
Also yes you should just simply read but honestly there's alot of crap to go through so idk why so many people always say to search and read. Hopefully this will give ya enough to start with.
P.s. I'd stay with the fuel injection if it's running just fine
theshackle
Sep 17, 2020 08:26 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
tero
Aug 15, 2015 02:47 PM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
