swap 305 tpi to a 400sb with 750 carb
Car: 1986Camaro Iroc z
Axle/Gears: 373 limited slip
Hello guys i want to swap my 305 tpi with a 400 rebuilded and upgraded its has a 750 carb. Wich mods i need to do on my car?, did i need to change the fuel pump or add a fuel pressure regulator?, what kind of pump or what kind of FPR? any comments or recommendations are appreciate.
Transmission: 4L80E/4L80E
The factory fuel pump will be fine. Use a return-type fuel pressure regulator like the Mallory 4309.
You'll have several adaptations to do, fuel lines, throttle cables, etc.
Sanjay
Aug 12, 2015 03:41 PM
