need info
Old May 18, 2015 | 04:59 PM
2004chevyman's Avatar
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
need info
ok ,i will need all the info that i can get,so, i am takeing out a 2.8 and putting in a 327 i guess what i am looking for is all the up and down info and i want all i can get and the do's and donts, so let it all begain thanks
Last edited by 2004chevyman; May 18, 2015 at 09:12 PM. Reason: not enough info on the car
Old May 18, 2015 | 09:15 PM
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: need info
the car that i am swapping engines out is a 1986 camaro and the it a 2.8 ,and the one i'am putting in is a 68-327 want to do away with the computer if i can
Old May 18, 2015 | 10:04 PM
357 Camaro's Avatar
Car: 92 camaro/99 gmc Z71
Engine: 357/5.3
Transmission: built 700r4 4500 stall/4l60
Axle/Gears: 4.56/?
Re: need info
https://www.thirdgen.org/forums/engi...swap-read.html
Old May 19, 2015 | 05:05 AM
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
Re: need info
thanks 357camaro for that info ,but if it had been a snake i would have gotten bit ,now i have a lot of work to do,i'am sure i will have some questions when i get deep into it thanks
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
