Wiring?
Old Jul 16, 2015 | 11:28 AM
firebird68025's Avatar
Car: 87 Firebird
Engine: 2.8 Liter
Wiring?
Will the wiring from a 1985 RS 5.7 liter work in a 1987 2.8 liter firebird? I'm swapping out the 2.8 for the 5.7.
Thanks!
Old Jul 16, 2015 | 04:34 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Wiring?
Thanks!
There was no 1985 RS. There was no 1985 5.7L. I don't know if someone is trying to sell you something under those premises but I'd be leery of anything he says even if it's because he doesn't know any better.
Will the harness work? There may be a few pins that need to be changed but yes, it can work. I'd suggest using an 87 harness. If its a TPI motor then find a TPI harness from an 87 and it'll slip in with no changes. If it's a carb'd 350 then you can modify your 2.8 harness to work accordingly.
Old Jul 19, 2015 | 02:07 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Wiring?
if running a carb, all you really need is the ignition power wire and the alternator wiring to make it run, but the coolant temp wire and oil pressure sending unit wires are almost the perfect length to hook up to a small block.
Old Jul 22, 2015 | 08:03 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiring?
I wouldnt recommend any 85 wiring in an 87
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
armybyrd
Dec 5, 2015 09:22 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
