Hi all,
I am trying to make my factory gauges (1992 firebird) work with my ls swap. I am using a spear tech modified stand alone harness and I bought the Hawks 3 wire coolant temp sender with pigtail but they didn't provide instructions on how to wire it. Can anyone provide insight for wiring this guy. I know 1 wire will connect to the gauge and the other 2 will be for the ls harness but I don't know which are which.
Also, I bought a new oil pressure sender that I will plumb in as a separate sensor for the factory gauge. Anyone know the pin out for that one?
Thank you
Thank you
Sorry, oil pressure sender is a 3 wire as well.
Thanks!
Thanks!
