TA to camaro v6 swap
Old Feb 16, 2016 | 09:15 AM
SBCkid1982's Avatar
I'm in the middle if my first motor swap on my 82 and I had a 2.8l in it and I pulled it bought a 350 and bought a trans am to use the 700r4 and I've come across a few problems with the trans crossmember I ended up putting in the trans am crossmember but I had to slide it up and only have two bolts it it the car isn't on the road yet I just need to know can I drill and tap the subframe or can I drill and notch a hole on each side just enough to fit a nut and a wrench in there
92g92
Nov 25, 2016 08:34 PM
Makaveli88
Aftermarket Product Review
Apr 21, 2016 09:12 PM
Phirewire
Feb 15, 2016 10:08 AM
LsxMatt
Feb 12, 2016 09:50 PM
ZZ42Fast
Feb 12, 2016 06:16 PM
