Mpfi v6 to tpi 350
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
Mpfi v6 to tpi 350
I know I seen a thread on here before but after searching for a while I couldn't find it again. I need info on what wiring harness changes I need to make to switch from an 89 maf v6 to an 87 maf tpi. I don't know if it makes any difference but the tpi motor is an aluminum headed corvette motor.
Re: Mpfi v6 to tpi 350
Thinking I should have posted this into electronics instead of motor swap... Still having trouble finding what I need to change. I'm very new to efi but what I have found is
1. I need to splice an additional injector on each side
2. Might need to extend wires for tps, maf, etc
Is that all harness wise that would need changed?
What do I need to do computer wise?
Transmission: T-5, TH350, T-5
I'd suggest finding an 89 tpi harness on the classified boards. Way easier. Use then a 89 '165 ecm and prom
I figured it would but I don't mind if its difficult. I can spend time on it but according to the wife I can't spend much more money on it.
So I guess those are the only harness alterations needed?
