2.8 MPFI to 5.7 carb - throttle bracket question
Old May 7, 2016 | 08:44 AM
cuda71ss's Avatar
Car: 1986 Chevy Camaro
Engine: 5.7L 350
Hello community,
First off, I have read the general V6 to V8 swap sticky. Didn't find anything to help with my question so I searched "2.8 to 5.7", came up with A LOT of results. I weeded through them and none of them ask about throttle linkages so here goes...hopefully you guys can help me out!
As you can see from the title, I swapped out my 2.8 V6 fuel injected to a stock 5.7 carb'ed V8. The V6 throttle body was equipped for a throttle cable, cruise cable, and transmission kick down cable. The V6 bracket obviously didn't fit a small block carburetor.
So after some time away from playing with toys/projects like this(kids tend to demand attention ), I am back to cleaning up my swap and trying to do things right. The top half of my 5.7 is:
My question for you guys is what bracket did you use to facilitate the throttle, cruise, and kickdown cables? I have a bracket that was hacked together for the throttle and kickdown, but doesn't have support for the cruise and the cables may not be at the correct angles. I want this done right this time and am having trouble finding solutions.
Old May 8, 2016 | 01:18 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: 2.8 MPFI to 5.7 carb - throttle bracket question
head to a junkyard and find an 80's Caprice or Cutlass with a 307 Olds engine in it... those had a throttle cable/tv cable bracket that bolted to the rear carb bolts and is the easiest/cleanest way to do it.
i don't know what to tell you about the cruise other than to start popping hoods on every rwd 80's GM car and truck with a small block that you see in the junkyard and grab whatever looks like it will work.
Old May 8, 2016 | 08:50 AM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
I used the TCI bracket, looks clean and lines up right. I've never seen anything that has the cruise control bracket....
Old May 8, 2016 | 01:24 PM
cuda71ss's Avatar
Engine: 5.7L 350
Dang...I was hoping someone would know of an aftermarket bracket that would do it all. Being that a lot of my engine compartment is already aftermarket looking, I'd prefer the bracket to look aftermarket too, something chrome would look nice. If not aftermarket, there's got to be a factory setup that were used for all 3 cables.
It's really easy to find a bracket for all 3 online, but seem to be for newer motors like the vortec.
If anyone knows, this has to be a place to find someone that does!
