gas leak
Old Aug 1, 2016 | 08:13 AM
jayonemo's Avatar
Engine: 355
Transmission: 350
Axle/Gears: 342
gas leak
My car leaks gas if it has over a half a tank. After driving it just drips and drips. My car guy thinks its the vent line plugged and forcing gas out. I know a hole is the easy answer but I changed tanks before and the leak is coming from somewhere above what I can see from below. anybody else had this problem with there sending unit.
Old Aug 1, 2016 | 08:19 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: gas leak
Never had the problem, but it could be the fuel tank filler neck is cracked at the tank connection, or the gasket at the tank pump/sender may be bad.
Old Aug 1, 2016 | 08:32 AM
jayonemo's Avatar
Engine: 355
Transmission: 350
Axle/Gears: 342
Re: gas leak
The fuel fill tube is up hi on the tank and i can see the bottom of it. I gonna pull the tank down and check it. I wanted to know about the plugged vent line.
Old Aug 2, 2016 | 07:05 AM
Re: gas leak
Take off the gas cap and see if it quits. If so, it's a vent problem. If not, it's a hole/crack/leak/etc.
90Iroc_Coup
Jul 30, 2016 11:33 PM
Steve
Southern California Area
Mar 28, 2016 10:09 PM
Funnyinaz?
Aftermarket Product Review
Jul 12, 2001 10:29 PM
camaro6spd
Apr 8, 2001 05:51 PM
theformula
Oct 16, 2000 06:49 PM
