Lt1 question
Old Aug 8, 2016 | 01:58 PM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
Lt1 question
OK I dropped a lt1 in my 87 firebird originally a v6 no harness in car got the harness and ecm from the donor car a 95 roadmaster but the guy cut the wires at the firewall that go threw to the inside of the car I need this car wired everything else is already done plz help
Old Aug 8, 2016 | 04:50 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: Lt1 question
I would first start by searching for LT1 swap threads and figure out what you have and what you need to get it wired, there is tons on information on this swap. once you get the basics on the swap down you can ask specific questions on where you are stuck and needing help.
If modifying the harness you have seems like its going to be to big of a task you can always buy a aftermarket harness that makes things much easier.
mecham84
Aug 15, 2016 06:45 PM
Baps
Aug 7, 2016 10:03 PM
Mattis
Jul 30, 2016 11:48 AM
MarcusAmble
Jun 7, 2016 10:21 PM
Matt91firebird
May 26, 2016 10:27 AM
