Sourcing out parts do you know were these are? (350 swap)
Old Sep 15, 2016 | 09:50 PM
mynameisfrank89's Avatar
Car: 1987 camaro irocZ
Engine: 350 tpi
Transmission: t5
So recently ive swapped my car and everything is ready and hooked up it just wont start but I realized i need a new distributor cause the icm went bad and its best to just replace the whole thing but while i was saving for that i was hoping i could finish the rest of the stuff i need and was wondering if you guys could give me some info on thesd parts like what cars i could get them from and were they might be located in these cars here are the parts i need
-350 esc module
-8746 ecm from tbi 350
-61 ft/lbs tbi injectors
Also i was told i need a 350 knock sensor however my 350 had a knock sensor in it so i was wondering if this is ok to use but im really just asking you guys were you guys mightve found these parts at if you know or did the swap all help is appreciated thanks
Old Sep 19, 2016 | 03:00 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Sourcing out parts do you know were these are? (350 swap)
The 350 might have a knock sensor compatible to the 7746 but you may as well pull it and the drainplug on the other side and install with correct thread sealant to correct torque before installing the engine so things are easier to service in case you find it's not compatible.
Do some digging on part numbers; there may have been a 7746 350 B-body application for module. Or, if a same-year 305 / 7747 truck uses the same ESC module, as a TBI 305 third gen, then a same year truck 350 module should work.
Old Sep 19, 2016 | 10:49 AM
Engine: 350 tpi
Transmission: t5
Ok
89irocz355
Exterior Parts for Sale
26
Feb 20, 2017 10:06 AM
89irocz355
16
Oct 3, 2016 11:03 PM
Anthony0128
Aug 19, 2016 04:54 PM
89irocz355
Aug 17, 2016 08:23 PM
89irocz355
Aug 17, 2016 08:20 PM
