Tv cable too long
Old Nov 8, 2016 | 10:04 PM
92kylecamaro's Avatar
Car: 92 25th anniversery camaro
Engine: 5.7l
Tv cable too long
Doing a 350 carb swap bought the Holley brackets from jegs getting it all hooked up and the tv cable is too long was wondering if anyone ran into the same problem and what cable you used
Old Nov 9, 2016 | 06:44 AM
Buickstaged's Avatar
Car: 1984 firebird se
Axle/Gears: 373
Re: Tv cable too long
92kyle - I had the same issue with a QF Carb - I bought a part called Sonnex cable adjuster - it takes the slack out of the cable - you can fine tune to however you want to shift, etc. I gives back adjustability. Research it a bit and see if you think that will work for you. I had to buy 4 or 5 of them. I have 3 or 4 left. Byron
Old Nov 9, 2016 | 11:02 AM
skinny z's Avatar
What did you swap from? TPI? TBI? There are cables of different lengths. If memory serves, the TPI cable isn't suited to a carb swap.
Old Nov 9, 2016 | 11:07 AM
Engine: 5.7l
tbi to carb I bought the stud that bolts on to the side of the carb it fits fine just too long
Old Nov 9, 2016 | 11:15 AM
skinny z's Avatar
You may need this TV cable corrector. The cable geometry is very precise and the stud has to be in the correct location.
Check this out.
https://www.holley.com/products/fuel...e/parts/20-121
Old Nov 9, 2016 | 11:24 AM
Engine: 5.7l
I have one of those and the bracket that the throttle cable and tv cable snap into that's bolted down on the carb stud I appreciate the help guys
Old Nov 9, 2016 | 11:27 AM
skinny z's Avatar
Maybe post up a picture of the situation. There are a number of variables that can affect the overall operation.
Old Nov 9, 2016 | 11:41 AM
Engine: 5.7l
I will have to do that tomorrow I'm at the hospital we just had our baby boy, if you zoom in on the pict above you can kind of see it I'll get a better pict tomorrow though
Old Nov 9, 2016 | 12:14 PM
skinny z's Avatar
Congratulations.
Old Nov 9, 2016 | 12:16 PM
Engine: 5.7l
Thank you
Old Nov 9, 2016 | 01:12 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
The issue is there is not enough adjustability in the Holley bracket. This is one of the reasons why I like the CSR bracket. You can adjust the throttle connection and the TV cable connection independently. I used the CSR bracket and my stock TPI throttle cable and TV cable. Worked fine.
Congrats on the little one! I have three myself. Never a dull moment!
Old Nov 9, 2016 | 01:23 PM
Engine: 5.7l
I'll have to check into that. This is my 3rd also, I wouldn't trade them for the world. I need to get this car running and driving though my oldest is 6 and he's not exactly into going to the garage to help me yet. I'm hoping that when he hears it loping and goes for a ride he will be more interested.
This is the 2 yr old she loves helping daddy
