carbed lt-1 swap???
Old Dec 29, 2001 | 11:06 AM
silentneko's Avatar
carbed lt-1 swap???
ok I can get a lt-1 engine from a camaro for about $900. first can this work with my q-jet. I'm looking for a direct replacement for my 305/lg4 engine, but only want to replace the longblock, I want to keep my carb and accesories. will this work or is a 350tpi a better donor motor, or should I find a 350 truck motor from a junk yard for $100 and rebuild it? what do you think
Old Dec 31, 2001 | 02:04 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I assume you are talking about a second gen lt1? I make the same mistake and put the - in there also. If you are speeking of a lt1 which I believe you are , this could be done fairly easily. You need the lt1 carb manifold from gm performance parts, a block off plate for the opti and possibly a new distributor(I don't know if yours will work or not You might need one with a distributor gear that works with the lt1 roller cam) THey did this swap in an issue of chevy high performance with an iron head lt1. THey added a hot cam kit and got over 400 hp out of it.
Hope this helps.
Kory
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
cRoe4
Aug 7, 2015 08:46 PM
