question
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
question
Hi
Im building a 383 from a 350 87 to 94 block
I have a 88 gta tpi now 305 t5
and I have everything about to build 383
I just got a set of bad *** alum heads custom made from a local shop
and they told me I may need longer push rods
he said stock or .100 to maybe .200 longer
now I don't really want to buy 2 sets of longer pushrods for nothing
can anyone tell me for sure if stock ones may work
im using my friends shop and its costing my money to use his shop
and if I get stuck with the stock ones not working I would have to wait weeks for new longer ones
I thought I would ask
ty
ty
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: question
You should use a 5/16 pushrods checker. Stock roller cam is 7.200 flat tappet 7.8
Engine: 383 built
Re: question
ok and how hard is it to install new melling oil pump
do you need press or does it bolt in
