Needing Advise for my engine swap
Old May 10, 2017 | 12:24 AM
Eric Robbins's Avatar
Car: 1989 Camaro RS
Engine: Stock 305, wanting to swap for 350
Im wanting to remove the stocl 305 in my RS and wanting to put in a 350, but what all would have to be done in order to do so such as fab work to have the motor sit in properly if any?? Thanks!
Old May 10, 2017 | 01:20 AM
L67ss's Avatar
Re: Needing Advise for my engine swap
Bolt in
Old May 10, 2017 | 07:55 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Virtually everything will swap over from the 305. Are you planning on keeping your entire induction system (carb, intake, air intake/filter, etc.) from the 305? Also, what year is the 350?
Old May 10, 2017 | 08:43 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Start by reading the 305 to 350 sticky thread and go from there
https://www.thirdgen.org/forums/tbi/...-350-swap.html
