305 to a 350 question
Old May 26, 2017 | 09:34 AM
Rgp88's Avatar
So I'm definitely a noob here and I understand might be another topic about this but I figured I'd see if this will work.
So I just got a 1986 trans am 5.0fi with no motor and tranny but I also got a 1987 trans am gta with motor and tranny but the body is no good. So I want to put the motor and tranny into the 1986. I was wondering how much work would it actually be. I have the ecm and wiring harness from the gta. But the thing I really need to know is the wiring harness on the driver side firewall by the brake booster will it have to be swapped out as well. Or can the wiring harnesses from the 5.0 work with the 5.7. Thanks to anyone that has some info for me.
Old May 26, 2017 | 10:26 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: 305 to a 350 question
I am going to bet it will be 98% perfect and 2% getting a few sensors hooked in with some minor wiring changes and you are set.
The main powertrain components, engine and transmission, work together with the ECM and are independent of the rest of the car.
Old May 26, 2017 | 11:41 AM
Rgp88's Avatar
Awesome thanks for your input.
Old May 26, 2017 | 11:55 AM
dmm3369's Avatar
Car: 83 Z28 / 89 IROC
Engine: 350's
Transmission: T5 WC / 700R4
Axle/Gears: Posi 3.73
85-87 harnesses are the same.
Old May 28, 2017 | 09:58 AM
Rgp88's Avatar
So even with putting a 5.7 back into a 5.0 it'll all be okay as long as the 5.7 ecm is in it correct. Sorry just trying to make sure I have it all together before jumping into this long project car
Old May 28, 2017 | 10:22 AM
Engine: 350 TPI L98
Transmission: WC T5
Dang. Now you've got me thinking about this. I have a 89 convertible with the 305. Now I'm thinking the best way to get my power output up is to replace the longblock and ECM.
This thread has everything you need to know:
https://www.thirdgen.org/forums/tpi/...i-350-tpi.html
Old May 28, 2017 | 10:41 AM
dmm3369's Avatar
Engine: 350's
Should be fine. The TPI setup does not really matter if its sitting on a 305 or 350 block. I know several people who have done this. Just change out the parts listed in the link above.
