350 Tbi???
Old Jan 1, 2002 | 11:01 PM
8RedBird8's Avatar
350 Tbi???
I was told that i could mount a 350 in my car and use the stock 305 tbi setup. Has anybody tried this?? Can i use the stock tbi unit, manifolds, computer, fuel pump, and everything else. Just buy a 350 long block and make it work. Would i need a larger tbi with bigger injectors (like the holley model)?? Any suggestions on getting best bang for the buck?
Old Jan 2, 2002 | 12:16 AM
88NOSTA's Avatar
yes all will bolt up
Old Jan 2, 2002 | 09:50 AM
Guest
Guest
Posts: n/a
Check out the TBI board, much more info than here.
Old Jan 2, 2002 | 04:16 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
As for high-po parts, you may be able to use some stuff from the 95-99 Tahoe/Yukon/Suburban line-up.
My '96 Yukon does remarkably well for a TBI 350, which is rated at 255hp.
Old Jan 7, 2002 | 10:32 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I recently replaced my TBI 305 with a 350.
Swap is best done by replacing injectors, knock sensor and module.You might need a chip too.
I had a custom chip burned for mine.Adjustable fuel pressure regulator makes it very tuneable,and may eliminate the need for bigger injectors,if it's internally stock.
350 TBI Injectors (2 req) Part# 17112493
Knock Sensor Part# 10456288
Knock Module Part# 16128261
-Rich-
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
