First time engine swap
Old Jul 24, 2017 | 08:40 PM
SuperMacDaddy's Avatar
Im swapping a carb 305 to an L98 350 in my 86 camaro. I have a vortec intake manifold and vortec heads, will I need anything else to use the vortec heads? Also, I'm looking for a gasket seat but Im not sure what to order, I would appreciate any links to something that will work for me. Do vortec heads use different gaskets then the stock 305/350 heads? Everything else should be the same right? water pump and brackets, etc. The heads are 906 vortecs
Old Jul 31, 2017 | 10:15 PM
sbcfever350's Avatar
Car: 92 firebird
Engine: Sbc 357
Axle/Gears: 4th Gen 3.42 Zexel Torsen
Re: First time engine swap
You will need vortec specific intake gaskets and intake bolts everything things else will bolt right up.
