Distributor setup
Old Aug 1, 2017 | 06:22 PM
PhoenixRisingbb's Avatar
Distributor setup
Hello I'm putting a 350 into my 87 firebird formula it originally had the 305 carburetor engine with the coil divorced setup and I want to switch to an HEI coil in cap setup and wanted to know what to do about the wires I know the pink and white are tach and ignition but what do the rest do??
Old Aug 1, 2017 | 06:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Distributor setup
The flat four connector is for ecm reference pulse.
Old Aug 1, 2017 | 07:19 PM
Since I'm going with a vacuum advanced HEI and not the electric advanced can those ecm wires be eliminated
Old Aug 1, 2017 | 07:31 PM
Engine: Lb9
Transmission: M20
Yes, I'm assuming your removing the ccc
Old Aug 1, 2017 | 08:06 PM
Yes I'm going with a holly with the kick down adapter
