305 Replacement Suggestions (First Swap)
Old Dec 1, 2017 | 11:11 PM
pmand's Avatar
Car: 1988 A4U (#99 SONY/Protec)
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
I’m looking at replacing my 1988 A4U 305 TPI (Stock, 187,000km). I have a line on 2 1987 engines for free. I’m only looking to keep the original engine and drop in a refreshed engine. First attempt at a swap on my won and I know the 1987 belt runs different. Can I pull the pulleys off the 1988 and install on the 1987 so I have the same routing? Anything else I need to look at before the swap to an older model? Thanks guys.
Old Dec 4, 2017 | 05:06 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 305 Replacement Suggestions (First Swap)
use the pulleys, water pump, etc all off your 88. They will bolt on the 87 with no problem.
Old Dec 4, 2017 | 06:08 PM
pmand's Avatar
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
Awesome! Thanks for the response aliceempire. No more excuses now I guess but get going...
Old Dec 4, 2017 | 06:09 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Question, are the replacement engines going to be 305 as well or are they 350.
Old Dec 4, 2017 | 06:13 PM
pmand's Avatar
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
Hi MY87LT. I'll be replacing with a 305TPI. It's more original to the car and between the 2 engines (1 complete w rebuilt heads and 1 missing ex manifold and throttle body) I'm only down $300 so it made sense. And I've never attempted a swap of any sort other than my CT70 lol... So I'm keeping it simple.
Old Dec 4, 2017 | 06:37 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Sounds like you have it all under control. Good luck on your swap and keep us posted with pictures if possible.
Old Dec 4, 2017 | 09:13 PM
pmand's Avatar
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
Lol ... Sure, now I actually have to follow through :roll eyes: You bet! I am hoping Xmas holidays will allow me the timeframe to get going.
