86 corvette motor/tran to 88 camaro
Re: 86 corvette motor/tran to 88 camaro
Not really. Corvettes used a water-proof version of the ECM that was mounted outside the driver compartment. There are enough differences on the Corvette TPI setup and accessory drive, that there's really not much reason to use a Corvette setup for a thirdgen swap.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
In 86 the vette used a inside mounted 1227265 ecm. The Under hood ecms didn’t show up until 90. You can use the same ecm but the memcal will have vats enabled. Not much special about a 86 l98 I think it would have iron heads.
thanks guys my old 2.8 was blown and I found a deal on a wrecked 86 vette and was going to swap into my body 88 z-28 [I had already changed motor/tranny out of 87 wrecked Camaro into it because when I got the 88 originally it had no motor/tranny or engine harness] so I was hoping that I could do the same swap
thanks guys
tjman
thanks guys
tjman
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
I don’t think the vett trans will mount up. Different torque arm mount right.
The motor, you can use; not the transmission. But if it was me I'd take the TPI off and sell it, and put some other intake system on it.
garage_engineer
385
Nov 5, 2024 08:44 AM
domina7e
Feb 3, 2018 12:48 AM
